9. Model Building#
9.1. Supply Editor#
Supply editor menu
There are elements in the Supply database that are rather static relationships between several elements of the network, and therefore atomic operations to enforce such would not make much sense.
To have access to these operations, one can access Menu Polaris → Supply Editor after opening the network, as shown on the imagine to the right.
There are two things to keep in mind before using any of these tools, however:
  • They may take a long time to run, depending on the size of the network
  • Data is deleted at the start of each process (with the exception of Global Geo-Consistency), so stopping said processes will break the supply file as far as Polaris is concerned.
These changes, which may depend on user input for specific parameters, are not expected to be frequent, as most of these changes are necessary when bulk data import is made to the network or new data (links, locations, zones, etc.), are introduced in the supply.
9.1.1. Global Geo-consistency#
Global Geo-consistency tool
The global-Geo-consistency tool is responsible for rebuilding the spatial references across tables required by Polaris, such as the Zone, link and walk link to which each location is associated.
The user may choose any combination of geo-associations to run, as they are independent processes that will be ran in sequence.
_images/blank.png
9.1.4. Rebuilding the Location_Parking table#
Rebuild Location_Parking tool
The Location_Parking table associates the closest parking facilities to each location.
During the table re-creation process, parking locations are created to coincide with the Location positions every time there is no pre-existing parking facility within the threshold determined by the user, which results in a Parking with potentially as many entries as the Location table. Additionally, parking facilities tagged as corresponding to a specific location are not associated to any other location on the Location_Parking table.
9.1.5. Fixing zones with no locations#
Zone with no locations tool
One of the common issues to prevent Polaris from running successfully is the existence of zones to which no locations are assigned. Although it would be reasonable to expect that the construction of the model would see that this does not happen, it is useful to have a method to quash that problem if it does happen.
In order to make sure the analyst is fully aware of the changes they are making to the supply file, this tool is built as a two-step process:
  1. First the user needs to identify all zones with no locations (which will be selected on the map)
  2. Execute the creation of one location per identified zone
