8. Transit & Active#
Transit and active menu has two main components (shown in the menu to the right):
Editing
Visualization
8.1. Editing#
Transit editing tools in QPolaris include GTFS import, creation of active transport (bike and walk) networks and direct Public Transport (PT) editing of stops, routes and patterns.
8.1.1. Public Transport Editing#
The PT editor can be opened from the Transit editing menu. It provides two tabs:
Stops editor
Routes/Patterns editor
8.1.1.1. Stops editor#
The Stops editor allows users to create, inspect and delete stops.
The upper section provides filters for existing stops by ID and name, plus buttons to load a stop into the form or delete it.
The lower form allows setting agency, route type, stop code, stop name, location and description for a new or updated stop.
8.1.1.1.1. Picking stop location from map#
To set coordinates directly from the map:
Click Pick Location from Map
Click the desired location on the map canvas
Confirm that longitude and latitude fields are populated
8.1.1.1.2. Saving and deleting stops#
After filling required fields (agency, route type and coordinates), click Save New Stop to add the stop to the model supply.
Deleting a stop requires selecting it in the table and confirming the action in the confirmation dialog.
8.1.1.2. Routes and patterns editor#
The Routes/Patterns editor is used to create routes, inspect existing patterns, build pattern stop sequences and create trips.
Selecting a route filters the map to that route, its patterns and associated stops. Selecting a pattern further filters the map to the selected pattern and its stops.
In Pattern Builder mode, users can click stops directly on the map to build a new sequence. Existing stops already used by the selected route patterns are shown with stronger visual emphasis to support faster pattern editing.
8.1.2. GTFS Import#
The main screen for GTFS import in the Polaris plugin includes the list of feeds already configured, a option to recreate the walk network after importing the transit feeds and three options to deal with existing transit tables: Keeping everything, deleting the data and purging all the tables, which results in dropping all tables and re-creating them according to the network standard that has shipped with the plugin. Choosing not to re-create active transport networks will result in all the new transit stops to be DISCONNECTED FROM THE REST OF THE NETWORK until the re-building of the active transport networks, and it is therefore discouraged.
To add feeds (no upper limit in the number of feeds you can add), the user can press the button Add Feed and use the file selection screen that will open to select the GTFS feed of choice as a zip file.
After selecting the feed, the calendar widget in the next screen will limit the choice of day for import according to the information available in the feed itself, and the day of choice is usually a Tuesday or Thursday, but the user is free to pick any day in the available range. Also note that entering text for the agency’s name and a description for it is mandatory.
In the following two tabs the user has the opportunity to choose the default route capacities per route type (see the GTFS specification for the correspondence between route types and physical modes), as well as to choose if a new table with raw transit route shapes (if available in the feed) should also be created alongside the Polaris transit tables.
8.1.3. Creating Active transport networks#
Selecting this option will show a menu with a button to start the process of creation of walk/bike networks. After pressing the button, it will IMMEDIATELY CLEAR TRANSIT_WALK AND TRANSIT_BIKE TABLES prior to rebuilding it (showing the progress bar below), so let it run through the end if you have pressed it by mistake.
8.2. Visualization#
There are two visualization tools for transit data in QPolaris, one for the Transit services themselves and one for multimodal routing.
8.2.1. Multimodal router#
The multimodal router tool in QPolaris has a few less resources than its traffic router, and that’s mostly due to the fact that there is a lot more information to show for the paths between any two locations in the network.
There are basically 4 controls needed to compute a multimodal route, as shown in the GUI on the right. The first one is the time of day one wants to compute a route for, followed by the origin and destination locations for the route, and finally the list of modes one wants to compute a route for, which includes Bus, Rail, Cycle, Walk, Park & Ride, Park & Rail, TNC and Ride and Micromobility.
When computing routes between an origin and a destination, the solution for each selected mode will be presented in a different layer (if found) and with a different marker style (squares, triangles, circles, etc). The multiple modes used in each route are represented using different colors, with Walk being green, bike being blue, transit in yellow and traffic links (i.e. TNC, P&R) in red.
Origin and destination for the route are also shown, with a circle in red for the origin and in black for the destination, as shown below.
8.3. Styling#
No styles for visualizing transit data are available at the moment
