Redistributing fleets based on new control totals
Redistributing fleets based on new control totals#
When the user has data on the expected joint distribution of the fleet across multiple categories, including Vehicle class, power train, ful and its vintage, as well as the distribution of the existing fleet, it is possible to use the Vehicle Redistribution procedure to run an Iterative-Proportional fitting over the original distribution to match targets, including the total fleet for each census tract in the modeled area.
Imports
from os.path import join
import os
from pathlib import Path
from tempfile import gettempdir
import pandas as pd
from polaris.utils.file_utils import get_caller_directory
from polaris.prepare.vehicle_distribution_updater.vehicle_distribution_updater import RedistributeVehicles
Input data
Let’s take a look at the input data
model_path = Path("/tmp/Grid")  # We can use any model directory, as that is only used to obtain the vehicle codes
pth = get_caller_directory().parent / "data" / "vehicle_redistribution"
  • Vehicle file
Note that this file is TAB separated
pd.read_csv(pth / "vehicle_distribution_chicago.txt", delimiter="\t").head()
TRACT POLARIS_ID VEHICLE_CLASS FUEL POWERTRAIN VINTAGE PROPORTION
0 17007010100 1000 CAR_COMPACT Elec BEV 0 0.003972
1 17007010100 1009 CAR_COMPACT Diesel Conventional 0 0.000000
2 17007010100 1010 CAR_COMPACT Diesel Conventional 1 0.000000
3 17007010100 1011 CAR_COMPACT Diesel Conventional 2 0.000000
4 17007010100 1012 CAR_COMPACT Gas Conventional 0 0.006155
  • Target file
pd.read_csv(pth / "target_2040_low.csv").head()
VEHICLE_CLASS POWERTRAIN FUEL VINTAGE PROPORTION
0 CAR_COMPACT Conventional Gas 0 0.01755
1 CAR_COMPACT Conventional Gas 1 0.01750
2 CAR_COMPACT Conventional Gas 2 0.01830
3 CAR_COMPACT Conventional Diesel 0 0.00000
4 CAR_COMPACT Conventional Diesel 1 0.00000
  • Zone weights
pd.read_csv(pth / "veh_by_zone_chicago.csv").head()
TRACT veh_count
0 17007010100 1353
1 17007010200 991
2 17007010300 1015
3 17007010400 1303
4 17007010500 2183
All our files need to be inside the same folder (pth, below)
rv = RedistributeVehicles(
    model_dir=model_path,
    veh_file=pth / "vehicle_distribution_chicago.txt",
    target_file=pth / "target_2040_low.csv",
    zone_weights=pth / "veh_by_zone_chicago.csv",
    fleet_mode=False,
Processing and saving results#
The convergence threshold can be as low as required, as it is nearly guaranteed to converge
rv.process(conv_threshold=0.001, max_iterations=50)
# Two convergence scatter plots are also saved with the outputs for a quick sanity check
rv.save_results(join(gettempdir(), "veh_distr.csv"))
  • Proportions for vehicle types
  • Zone totals
Iteration 1: 0.0s , error 0.1775
Iteration 2: 0.0s , error 0.01309
Iteration 3: 0.0s , error 0.00106
Iteration 4: 0.0s , error 9e-05
Total processing time: 0.1s
Looking at the outputs#
import pandas as pd
df = pd.read_csv(join(gettempdir(), "veh_distr.csv"))
df.head()
TRACT VEHICLE_CLASS FUEL POWERTRAIN VINTAGE PROPORTION POLARIS_ID
0 17007010100 CAR_COMPACT GAS ISG 1 0.014504 NaN
1 17007010100 CAR_COMPACT GAS ISG 2 0.015163 NaN
2 17007010100 CAR_COMPACT GAS PHEV 0 0.000907 NaN
3 17007010100 CAR_COMPACT GAS PHEV 1 0.000907 NaN
4 17007010100 CAR_COMPACT GAS PHEV 2 0.000950 NaN
Total running time of the script: (0 minutes 0.656 seconds)
Gallery generated by Sphinx-Gallery
