Note
Go to the end to download the full example code.
Simplifying a model network#
This example shows how to leverage Polaris-Studio tools to suggest possible simplifications on Polaris networks that are deemed too dense. The main idea is to execute a static traffic assignment using an arbitrary full demand matrix and look into which links were actually used during the assignment.
The procedure allows the user to execute an All-or-Nothing assignment or an equilibrium assignment, which causes flows to spread out and therefore yields a larger number of links and a better connected network.
The algorithm is a basic heuristic, however, and we recommend users to use caution and thoroughly review its results when simplifying networks.
Icon source: https://foto.wuestenigel.com/strainer-in-close-up
Imports#
import shutil
from pathlib import Path
from uuid import uuid4
import numpy as np
# Figure out where our polaris directory is (so we can get some test data)
from polaris.utils.database.data_table_access import DataTableAccess
from polaris.prepare.supply_tables.network.traffic_links import used_links_traffic
from polaris.runs.static_assignment.static_graph import StaticGraph
from polaris.utils.database.db_utils import commit_and_close
from polaris.utils.testing.temp_model import TempModel
⚠️ Friendly exception handler is disabled via FRIENDLY_ERRORS_DISABLED
sphinx_gallery_thumbnail_path = ‘../../examples/model_building/strainer_in_close_up.png’
# Creates a new supply file with the chosen SRID
temp_model = TempModel("Grid")
source = temp_model / "Grid-Supply.sqlite"
supply_file = temp_model / f"{uuid4().hex}-Supply.sqlite"
shutil.copy(source, supply_file)
PosixPath('/tmp/polaris_studio_testing/2026-08-28_10-05-10--eac4462285b2/8b74910d7d4c4c5cb7fdef6e32c84acc-Supply.sqlite')
graph = StaticGraph(supply_file).graph
/venv-py312/lib/python3.12/site-packages/geopandas/array.py:1770: UserWarning: CRS not set for some of the concatenation inputs. Setting output's CRS as NAD83 / UTM zone 16N (the single non-null crs provided).
return GeometryArray(data, crs=_get_common_crs(to_concat))
2026-08-28 10:05:11 UTC+0000 - Field(s) a_node_network, source has(ve) at least one NaN value. Check your computations
/venv-py312/lib/python3.12/site-packages/aequilibrae/paths/graph.py:218: ChainedAssignmentError: A value is being set on a copy of a DataFrame or Series through chained assignment.
Such chained assignment never works to update the original DataFrame or Series, because the intermediate object on which we are setting values always behaves as a copy (due to Copy-on-Write).
Try using '.loc[row_indexer, col_indexer] = value' instead, to perform the assignment in a single step.
See the documentation for a more detailed explanation: https://pandas.pydata.org/pandas-docs/stable/user_guide/copy_on_write.html#chained-assignment
build_compressed_graph(self, remove_dead_ends)
# The most basic use is to figure out which links are part of the shortest path between any two zones
links_usage = used_links_traffic(graph, 0.1, algorithm="all-or-nothing")
# # Or we can use biconjugate Frank-Wolfe with this heavily congested network to *spread the flow* a little
# # That would result in a larger number of links being used
# The default number of iterations when algorithm and max_iterations are not provided is 50, which may take a little
# to compute when the network is very large and the number of zones is high
# links_usage = used_links_traffic(graph, 0.1, max_iterations=10)
# Let's get the links that ended up having flow on them (were part of at least one shortest path)
links_to_keep = links_usage.link_id.to_numpy()
# That's what we get back from our little algorithm
links_usage.head()
2026-08-28 10:05:11 UTC+0000 - Traffic Class specification
2026-08-28 10:05:11 UTC+0000 - {'car_usage': {'Graph': "{'Mode': '', 'Block through centroids': True, 'Number of centroids': 15, 'Links': 1058, 'Nodes': 463}", 'Matrix': "{'Source': '', 'Number of centroids': 15, 'Matrix cores': ['demand'], 'Matrix totals': {'demand': 22.5}}"}}
2026-08-28 10:05:11 UTC+0000 - Traffic Assignment specification
2026-08-28 10:05:11 UTC+0000 - {'VDF parameters': {'alpha': 0.1, 'beta': 2.0}, 'VDF function': 'bpr', 'Number of cores': 80, 'Capacity field': 'capacity', 'Time field': 'time', 'Algorithm': 'all-or-nothing', 'Maximum iterations': 250, 'Target RGAP': 0.0001}
car_usage : 0%| | 0/15 [00:00<?, ?it/s]
2026-08-28 10:05:11 UTC+0000 - all-or-nothing Assignment stats
2026-08-28 10:05:11 UTC+0000 - Iteration, RelativeGap (AoN), stepsize
Equilibrium Assignment : 0%| | 0/50 [00:00<?, ?it/s]
2026-08-28 10:05:11 UTC+0000 - all-or-nothing Assignment finished. 1 iterations, final AoN rgap = inf
YOU PROBABLY ALSO WANT TO KEEP ALL LINKS THAT ARE OF A CERTAIN HIERARCHIES
keep_types = ["FREEWAY", "MINOR", "MAJOR", "RAMP", "EXPRESSWAY", "PRINCIPAL", "FRONTAGE", "BRIDGE", "TUNNEL"]
links = DataTableAccess(supply_file).get("link")
links = links[links["type"].isin(keep_types)]
links_to_keep = np.unique(np.hstack([links_to_keep, links.link]))
WARNING
WE HIGHLY RECOMMEND REVIEWING THE RESULTS OF THE PROCEDURE ABOVE. YOU WILL LIKELY HAVE TO TUNE ITS PARAMETERS IT IS ALSO LIKELY THAT YOU WILL HAVE TO FIX SOME ISSUES IN THE NETWORK MANUALLY.
We can now delete the links that we are not going to use
with commit_and_close(supply_file, spatial=True) as conn:
sql = "DELETE FROM Link WHERE link NOT IN (" + ",".join([str(x) for x in links_to_keep]) + ")"
conn.execute(sql)
Total running time of the script: (0 minutes 3.451 seconds)
