Note
Go to the end to download the full example code.
Static Traffic Assignment#
We can also run the Polaris Activity-Based model with static assignment, including for model calibration exercises.
Even when the intention is to use Polaris powerful dynamic traffic assignment, this mode may be useful in speeding up the calibration process or obtaining a more realistic starting for the equilibration of skim matrices.
For this integration we have used [AequilibraE](https://www.aequilibrae.com/), which is an open source modelling package with incredibly fast static assignment capabilities, but similar integrations are possible with other packages.
Exporting matrices#
sphinx_gallery_thumbnail_path = ‘../../examples/modelling_like_the_old_days/pol_aeq.png’
from pathlib import Path
from polaris import Polaris
from polaris.runs.scenario_file import load_yaml, save_yaml
from polaris.runs.static_assignment.static_assignment_inputs import STAInputs
from polaris.runs.static_assignment.static_run import static_run
from polaris.utils.testing.temp_model import TempModel
We create a new model directory with a grid network that has already been run
project_dir = TempModel("Grid")
Before anything else, we mark it for a single iteration
config = load_yaml(Path(project_dir) / "polaris.yaml")
config["do_skim"] = False
config["do_abm_init"] = False
config["num_abm_runs"] = 1
save_yaml(Path(project_dir) / "polaris.yaml", config)
Now we run a single iteration of Polaris with static assignment
sta_param = STAInputs()
sta_param.max_iterations = 1 # You obviously want a MUCH higher number of iterations
sta_param.rgap = 0.1 # And a much tighter rgap
sta_param.num_cores = 5 # Delete this line to use all of your cores
# We would normally compute the KPIs, but let's leave it out to make the example faster
static_run(project_dir, sta_param=sta_param, save_assignment_results=True, run_kpis=False)
/venv-py312/lib/python3.12/site-packages/geopandas/array.py:1770: UserWarning: CRS not set for some of the concatenation inputs. Setting output's CRS as NAD83 / UTM zone 16N (the single non-null crs provided).
return GeometryArray(data, crs=_get_common_crs(to_concat))
combined : 0%| | 0/15 [00:00<?, ?it/s]
Equilibrium Assignment : 0%| | 0/1 [00:00<?, ?it/s]
Total running time of the script: (0 minutes 10.798 seconds)
