Simplifying networks
Simplifying networks#
In this example we show how to perform topological simplification on a network.
This process changes the data in place, so we recommend working on a copy of your model, as done below.
import shutil
from pathlib import Path
import folium
from polaris import Polaris
from polaris.utils.testing.temp_model import TempModel
⚠️ Friendly exception handler is disabled via FRIENDLY_ERRORS_DISABLED
sphinx_gallery_thumbnail_path = ‘../../examples/editing_models/simplification.gif’
original_model = TempModel("Grid")
target = original_model.parent / "simplified_grid"
shutil.copytree(original_model, target, dirs_exist_ok=True)
PosixPath('/tmp/polaris_studio_testing/simplified_grid')
A little function to plot the network, which we will use a few times
def make_map(network):
    network.tables.refresh_cache()
    links = network.tables.get("Link")
    nodes = network.tables.get("Node")
    map = links.explore(color="black", style_kwds={"weight": 1}, tool_tip="link_type", name="links")
    map = nodes.explore(m=map, color="red", style_kwds={"radius": 3, "fillOpacity": 1.0}, name="nodes")
    folium.LayerControl().add_to(map)  # Add a layer control button to our map
    return map
Let’s plot the network we have to begin with
network = Polaris.from_dir(target).network
make_map(network)
2026-08-28 10:05:42 UTC+0000 - Working with file on /tmp/polaris_studio_testing/simplified_grid/Grid-Supply.sqlite
Make this Notebook Trusted to load map: File -> Trust Notebook
Now let’s simplify the network
# Let's allow links to be a maximum of 2000 meters long
# And we will merge links if they have up to 5% difference in speed
# The recommended maximum length is 1,000, but we are using 100,000 here for illustration purposes
network.tools.simplify_network(maximum_allowable_link_length=100_000, max_speed_ratio=1.05, rebuild_network=False)
# What happened to the network after this simplification?
make_map(network)
/home/gitlab-runner/builds/polaris/code/polarislib/polaris/network/tools/network_simplifier.py:31: UserWarning: This will alter your database in place. Make sure you have a backup.
  warnings.warn("This will alter your database in place. Make sure you have a backup.")
/venv-py312/lib/python3.12/site-packages/geopandas/array.py:1770: UserWarning: CRS not set for some of the concatenation inputs. Setting output's CRS as NAD83 / UTM zone 16N (the single non-null crs provided).
  return GeometryArray(data, crs=_get_common_crs(to_concat))
2026-08-28 10:05:44 UTC+0000 - Field(s) a_node_network, source has(ve) at least one NaN value. Check your computations
/venv-py312/lib/python3.12/site-packages/aequilibrae/paths/graph.py:218: ChainedAssignmentError: A value is being set on a copy of a DataFrame or Series through chained assignment.
Such chained assignment never works to update the original DataFrame or Series, because the intermediate object on which we are setting values always behaves as a copy (due to Copy-on-Write).
Try using '.loc[row_indexer, col_indexer] = value' instead, to perform the assignment in a single step.
See the documentation for a more detailed explanation: https://pandas.pydata.org/pandas-docs/stable/user_guide/copy_on_write.html#chained-assignment
  build_compressed_graph(self, remove_dead_ends)
2026-08-28 10:05:46 UTC+0000 - 459 links will be removed
2026-08-28 10:05:46 UTC+0000 - 149 links will be added
2026-08-28 10:05:47 UTC+0000 - Old distance: 427442.36285424477, new distance: 427442.36285424477. Difference: 0.0
2026-08-28 10:05:47 UTC+0000 - Network has been rebuilt. You should run this tool's rebuild network method
We can also delete links and collapse them into nodes For this operation, we just choose an arbitrary link to delete here
network.tools.collapse_links_into_nodes(links=[838], rebuild_network=False)
# What happened to the network after this deletion?
make_map(network)
2026-08-28 10:05:47 UTC+0000 - 1 links collapsed into nodes
Now we can close the network
network.close()
Total running time of the script: (0 minutes 7.890 seconds)
Gallery generated by Sphinx-Gallery
