Note
Go to the end to download the full example code.
Setting user parameters#
There are a few procedures in POLARIS that require user-provided parameters, such as API keys. To handle these parameters in a user-friendly way, POLARIS uses a configuration file that is stored in the user’s configuration directory.
Once set, these values will remain available until the user changes them or deletes the configuration file.
sphinx_gallery_thumbnail_path = ‘../../examples/working_with_models/parameters.png’
from polaris.utils.user_configs import UserConfig
import json
⚠️ Friendly exception handler is disabled via FRIENDLY_ERRORS_DISABLED
# Most configuration values are initialized empty
for k, v in json.loads(UserConfig().model_dump_json()).items():
print(f"{k}: {v}")
census_api:
mobility_database_api:
nlr_api:
last_model_opened: /tmp
osm_url: http://overpass-api.de/api
overture_url: s3://overturemaps-us-west-2/release/latest
2. Setting values#
You can set your own API values (example below uses dummy values). Setting them automatically saves to the user configuration file.
UserConfig().census_api = "sk-4f8b2c1e7d9a4e3b8f6c2d1a0b5e7c9f"
UserConfig().mobility_database_api = "mdb-4f8b2c1e7d9a4e3b8f6c2d1a0b5e7c9f-1234567890abcdef1234567890abcdef12345678sadf"
2026-08-28 10:06:23 UTC+0000 - Configurations, including API keys, are stored as plain text in /root/.config/polaris/polaris_user_configs.json
Loading them now will return the values you set
print(f"{k}: {v}")
census_api: sk-4f8b2c1e7d9a4e3b8f6c2d1a0b5e7c9f
mobility_database_api: mdb-4f8b2c1e7d9a4e3b8f6c2d1a0b5e7c9f-1234567890abcdef1234567890abcdef12345678sadf
nlr_api:
Total running time of the script: (0 minutes 1.789 seconds)
