polaris.network.network.Network#
class polaris.network.network.Network#
Bases: object
Polaris Network Class
# We can open the network just to figure out its projection
from polaris.network.network import Network
n = Network()
n.open(source)
# We get the projection used in this project
srid = n.srid
# Or we can also get the checker for this network
checker = n.checker
# In case we ran some query while with the database open, we can commit it
n.commit()
# We can create a new network file from scratch as well
new_net = Network()
new_net.srid = srid # We use the SRID from the known network, for example
# if we don't have Spatialite on our system path environment variables, we can
# add it manually before attempting to create a new database
new_net.add_spatialite('path/to/spatialite/folder')
# If the second parameter is True, an SQLite file pre-populated with Spatialite extensions is used
new_net.new('path/to/new/file', True)
# To close the connection is simply
n.close()
__init__()#
Instantiates the network
Methods
__init__()
clear_log()
Clears log file
close([clear_issues])
Closes database connection
create(network_file, srid[, jumpstart])
Creates new empty network file
from_file(network_file[, run_consistency])
full_rebuild()
Rebuilds all network components that can be rebuilt automatically.
get_intersection(node)
Network intersection class
get_location(location_id)
Location object
has_edit_table(path_to_file)
new(network_file[, jumpstart])
open(network_file[, run_consistency])
Opens project for editing/querying
upgrade([redo_triggers])
Updates the network to the latest version available
Attributes
active
Active transport network creation class
checker
Network checker class
diagnostics
geo_consistency
Geo-consistency analysis class
geotools
ie
Network Import-Export class
open_data
populate
tables
tools
Tools for general manipulation of the network
transit
Transit manipulation class
__init__()#
static from_file(network_file: PathLike, run_consistency=False)#
static create(network_file: PathLike, srid: int, jumpstart: bool = False) None#
Args:
network_file (str): Full path to the network file to be opened.
jumpstart (bool): Copies base sql already loaded with spatialite extension. It saves a few seconds of runtime.
new(network_file: str, jumpstart=False) None#
open(network_file: PathLike, run_consistency=False)#
Args:
upgrade(redo_triggers=True) Network#
close(clear_issues=False)#
full_rebuild()#
Rebuilds all network components that can be rebuilt automatically. Designed to be used when building the network from scratch or making changes to the network in bulk. This method runs the following methods in order:
  • Rebuilds the location_links table
  • Rebuilds the location_parking table
  • Rebuilds intersections, where signalized intersections are sourced from OSM and all stop signs are added
  • Rebuilds the active networks
  • Run full geo-consistency
  • Deletes all records from the editing table
property tools: Tools#
property transit: Transit#
property active#
property checker#
property populate#
property diagnostics#
property geo_consistency#
property open_data: OpenData#
property geotools#
property tables: DataTableAccess#
property ie: NetworkImportExport#
get_location(location_id: int) Location#
Location object
get_intersection(node: int) Intersection#
clear_log()#
Clears log file
static has_edit_table(path_to_file)#
