Creating a new model supply#
Creating new models supply files is not a trivial task, so you should not underestimate the time it takes to do it.
This section presents a general guide for creating the supply components for new models. Automated tools are available whenever possible, but substantial manual work is still required.
During the creation of the supply model, you should also refer to the network data model, which is described in detail in Network Data Model.
Zero data alternative#
If you want to create a new model in a completely automated manner, you can refer to an example here: model_from_scratch. Multiple other tables are still required after following that example, but a guide for creating those tables is provided below in the Internal consistency components section.
Note
Even when using automated creation of networks, the user will likely have to use some of the resources listed in the next section of this documentation.
From existing data#
More often than not, transport models are created from components of existing models, particularly networks and zoning systems. For this reason, we go through the process of building supply models one step at a time, where networks and zoning systems are imported from existing data sources.
Links and Nodes#
Creating tables for nodes and links from existing data involves multiple steps, but they will vary substantially depending on the source of the data. Networks coming from Cube or Emme are usually more involved to import than those coming from TransCAD, for example.
Instead of attempting to describe the process for each possible source of data, we provide below the most important points to consider when importing networks into a Polaris supply model.
Links are bi-directional, so all information for both flow directions are contained in separate fields. This is particularly important when importing networks from software that represent link directions separately.
The AB direction of the link is the link topology. This means that the A node is the first node in the link as drawn, and the B node is the second node as drawn.
the node_a and node_b fields in the links table are filled automatically and correspond to the appropriate nodes from the Node layer. New nodes are created when no node is in the exact coordinates the link starts/ends at.
Links that have a positive number of lanes for a given direction (lanes_ab/ba) should have a positive speed for that direction (fspd_ab/ba).
There are other fields are filled automatically. Refer to Link for details.
No two nodes can have the exact same coordinates.
Note
If maintaining node numbers is important to you, then you MUST import network nodes before importing links, and must ensure that the geometry of nodes and links match PERFECTLY.
Zoning#
Polaris has a substantial number of fields that are required for proper model operation, but they are not necessary at the time of the model build. For a full documentation of these fields, please refer to zone table structure.
The most important points to consider when importing zone systems are:
zone is The zone ID and a required field
area_type: The area type of the zone and a required field, but the user can use the value of 100 as the default value.
Geometries are strictly required for Zones.
Counties#
The counties layer is only necessary in Polaris for the use of the freight model, and therefore can be skipped if the user prefers. The documentation for this table can be found at counties table structure.
Note
The county data must added to the model AFTER the zones have been added, and it is crucial that the year chosen corresponds to the data planned to be used in the freight model.
from polaris.network.network import Network
net = Network.from_file(path/to/supply-model.sqlite, run_consistency=False)
net.populate.add_counties(year=2022)
Locations#
Adding locations is a quite demanding task, and it is unlikely that you will have that data from other models. If you do, the it is critical to pay attention to the land_use field, which is intimately tied to the inner workings of Polaris. Please refer to the documentation of location table structure for acceptable values for this field.
Also remember that the Land_Use table will have to be populated with the adequate data before adding locations to the Supply file. See land use table structure for documentation on that table.
If you have no data for locations, you can follow the example in model_from_scratch on how to create these locations automatically. Documentation on the API is below.
# We need control totals for each non-residential land use type for each location
# The Polaris development team currently maintains control totals for the US at census tract level
# A census API key is required to download control totals for residential locations
control_totals = gpd.read_file(rootdir / "control_totals.parquet")
net.populate.add_locations(
control_totals=control_totals,
census_api_key=os.environ.get("CENSUS_API_KEY"),
residential_sample_rate=0.25,
other_sample_rate=1.0,
Parking#
The Parking table is detailed on parking table structure in case you have data to add to it manually. If you don’t have data, you can follow the example in model_from_scratch on how to create these facilities automatically.
Note
Filling this table is not required, as it will be populated with a parking per location by default when the Location_Parking table is filled if not suitable parking facility is found.
Below there is an example for the API use.
# We add location facilities from Open-Street Maps
# The default OSM parking tags downloaded are ("surface", "underground", "multi-storey", "rooftop")
net.populate.add_parking()
EV Chargers#
It is likely that you also don’t have data on EV chargers to add to the model. In that case, you can resort to the automatic data shown in model_from_scratch and in the code excerpt below.
If adding EV chargers manually, please refer to the table’s documentation at ev charging stations table structure.
# Polaris-Studio has an heuristic to cluster EV chargers into single stations whenever they are
# too close to each other. The default parameters are 5 clustering attempts and a maximum distance
# of 50 meters between chargers. An API key from NREL is required to download the data.
net.populate.add_ev_chargers(os.environ.get("EV_API_KEY"), max_dist=50, clustering_attempts=5)
The Documentation of the supply populator class is below.
Transit#
Transit systems are not mandatory for Polaris to work.
Adding Public transport data to a Polaris Supply model can be done by importing GTFS zipped files, and multiple options are available to customize the results of the importing process. Among these customizations are:
Map-match the transit routes onto the roadway network. This is only relevant when simulating bus in traffic or when results need to be mapping precisely
Correcting schedules to ensure that time between consecutive stops don’t imply unrealistic speeds
Importing the route shapes as included in the GTFS feed (a.k.a. raw shapes)
A lengthy description of the mechanics of the GTFS importer and all its options are all available the Public Transport section of this documentation
Programmatically adding public transport routes is also possible, and is described in an example at Editing Public Transport Route System.
Micro-mobility#
Micro-mobility systems are not mandatory for Polaris to work, and there are no automated tools for collecting data on these systems. The user is encouraged to look into the documentation for the two tables required for this data: micromobility docks table structure and micromobility agencies table structure.
Internal consistency components#
There are multiple tables in the Supply database that do not depend on external data, but which are still required by Polaris. Polaris-Studio has a set of tools to build these tables, but the user is required to execute these procedures manually. Polaris is great, but it can’t read its users minds (yet) to realize they are done with external data inputs.
Transit_Walk and Transit_bike#
Active transport networks (walk and bike) are represented in separate tables in the supply database, but are currently exactly the same, as no Polaris model included walk-only or bike-only links. Polaris-Studio has a tool to build these tables that is accessible from both the QGIS plugin and from Python, which is exemplified below.
active = net.active
# We can set a maximum length for walk links if we would like. This would break links longer than this
# active.set_max_link_dist(200)
active.build()
Walking & Biking network building class |
Connections#
The Connections table is a strict requirement of Polaris, as links are not considered connected if there are no turns listed on this table. Intersection control is not mandatory to exist, as Polaris defaults to 4-way stops, but it is recommended that you are appropriate signal and stop information, which is codified on a series of tables, documented on signal table structure and sign table structure.
Adding connections to the supply model is fairly simple, as there is a tool for such, which is exemplified below. When setting signals to “osm”, the tool will retrieve traffic light location information from OpenStreet-Maps, and setting signs to [] tells the software to put stop signs on each intersection after analysing potential rights of way to decide if those stop signs should be of the 4-way or 2-way kind.
tools = net.tools
tools.rebuild_intersections(signals="osm", signs=[])
More detailed documentation on the traffic components can be found at Traffic elements
Location-Links#
The Location_Links table is strictly required by Polaris, and specifies through which link can the trips originated/destinated at each location can access the network. The user can specify the maximum distance from the location to the network, and whether multiple links are allowed.
It is highly recommended to stick to the default parameters for this function.
tools = net.tools
tools.rebuild_location_links()
# Can be parameterized as below
#tools.rebuild_location_links(maximum_distance=300, multiple_links=True)
Note
Regardless of the maximum distance parameter, Polaris-Studio will always add at least one link per location to this table.
Location-Parking#
The Location_Parking table is strictly required by Polaris, and specifies the parking location to be used for accessing each specific Location. The user must provide a maximum distance for parking facilities to be considered.
Note
In the event a Parking facility within the acceptable distance is not found found, a new parking facility dedicated to the specific Location will be added to the Parking table and a record linking that parking facility to the location will be added to the Location_Parking table.
tools = net.tools
tools.rebuild_location_parking(maximum_distance=300)
API#
Tools for general manipulation of the network |
