Note
Go to the end to download the full example code.
Changing the Projection system for a model#
In this example we show how to change the projection system for a Polaris model.
Image credit to: https://ubc-library-rc.github.io/map-projections/content/diffs-geo-proj.html
from polaris import Polaris
from polaris.network.network import Network
from polaris.project.project_restorer import create_db_from_csv
from polaris.utils.database.db_utils import commit_and_close
from polaris.utils.database.standard_database import DatabaseType
from polaris.utils.path_utils import tempdirpath
from polaris.utils.testing.temp_model import TempModel
⚠️ Friendly exception handler is disabled via FRIENDLY_ERRORS_DISABLED
sphinx_gallery_thumbnail_path = ‘../../examples/editing_models/projections.jpg’
model_path = TempModel("Grid")
model = Polaris.from_dir(model_path)
model.upgrade()
old_net = model.network
2026-09-01 07:25:20 UTC+0000 - Upgrading Freight database at location /tmp/polaris_studio_testing/2026-09-01_07-25-20--ea58877cc615/Grid-Freight.sqlite
2026-09-01 07:25:20 UTC+0000 - No migrations to apply
2026-09-01 07:25:20 UTC+0000 - Upgrading Freight database at location /tmp/polaris_studio_testing/2026-09-01_07-25-20--ea58877cc615/Grid-Freight.sqlite: Done in 0:00:00.003622 seconds
2026-09-01 07:25:20 UTC+0000 - Upgrading Demand database at location /tmp/polaris_studio_testing/2026-09-01_07-25-20--ea58877cc615/Grid-Demand.sqlite
2026-09-01 07:25:20 UTC+0000 - Upgrading Demand database at location /tmp/polaris_studio_testing/2026-09-01_07-25-20--ea58877cc615/Grid-Demand.sqlite: Done in 0:00:00.001246 seconds
2026-09-01 07:25:20 UTC+0000 - Upgrading Supply database at location /tmp/polaris_studio_testing/2026-09-01_07-25-20--ea58877cc615/Grid-Supply.sqlite
2026-09-01 07:25:20 UTC+0000 - Upgrading Supply database at location /tmp/polaris_studio_testing/2026-09-01_07-25-20--ea58877cc615/Grid-Supply.sqlite: Done in 0:00:00.010532 seconds
2026-09-01 07:25:20 UTC+0000 - Working with file on /tmp/polaris_studio_testing/2026-09-01_07-25-20--ea58877cc615/Grid-Supply.sqlite
WARNING
BE CAREFUL WHEN CHOOSING A PROJECTION SYSTEM. It must be projected in meters for Polaris to function properly
reprojected_folder = tempdirpath() / "new_projection"
# Let's say we choose the projection system 5069
old_net.ie.dump(reprojected_folder, target_crs=5069)
new_net_file = tempdirpath() / "Grid-Supply_reprojected.sqlite"
create_db_from_csv(new_net_file, reprojected_folder, DatabaseType.Supply, overwrite=True)
2026-09-01 07:25:21 UTC+0000 - Creating empty db: /tmp/Grid-Supply_reprojected.sqlite (jumpstart=True, with_defaults=True)
2026-09-01 07:25:21 UTC+0000 - Creating file at /tmp/Grid-Supply_reprojected.sqlite
2026-09-01 07:25:21 UTC+0000 - Adding Spatialite infrastructure to the database
2026-09-01 07:25:21 UTC+0000 - Creating Tables
2026-09-01 07:25:21 UTC+0000 - Creating Tables: Done in 0:00:00.248538 seconds
2026-09-01 07:25:21 UTC+0000 - Creating empty db: /tmp/Grid-Supply_reprojected.sqlite (jumpstart=True, with_defaults=True): Done in 0:00:00.306432 seconds
2026-09-01 07:25:21 UTC+0000 - Deleting triggers
2026-09-01 07:25:21 UTC+0000 - Deleting indices
2026-09-01 07:25:22 UTC+0000 - Recreating indices
2026-09-01 07:25:22 UTC+0000 - Creating triggers for version 20260512
2026-09-01 07:25:22 UTC+0000 - -- 15 zone(s) have X or Ys that differ from the geometry by more than 0.1 m
2026-09-01 07:25:22 UTC+0000 - -- 38 Transit_Stops(s) have X or Ys that differ from the geometry by more than 0.1 m
2026-09-01 07:25:22 UTC+0000 - -- 448 location(s) have X or Ys that differ from the geometry by more than 0.1 m
2026-09-01 07:25:22 UTC+0000 - -- 2 Micromobility_Docks(s) have X or Ys that differ from the geometry by more than 0.1 m
2026-09-01 07:25:22 UTC+0000 - -- 218 location(s) have X or Ys that differ from the geometry by more than 0.1 m
2026-09-01 07:25:22 UTC+0000 - -- 2 EV_Charging_Stations(s) have X or Ys that differ from the geometry by more than 0.1 m
2026-09-01 07:25:22 UTC+0000 - -- 1 zone(s) have X or Ys that differ from the geometry by more than 0.1 m
2026-09-01 07:25:22 UTC+0000 - Consistency errors found in Supply database ['-- 15 zone(s) have X or Ys that differ from the geometry by more than 0.1 m', '-- 38 Transit_Stops(s) have X or Ys that differ from the geometry by more than 0.1 m', '-- 448 location(s) have X or Ys that differ from the geometry by more than 0.1 m', '-- 2 Micromobility_Docks(s) have X or Ys that differ from the geometry by more than 0.1 m', '-- 218 location(s) have X or Ys that differ from the geometry by more than 0.1 m', '-- 2 EV_Charging_Stations(s) have X or Ys that differ from the geometry by more than 0.1 m', '-- 1 zone(s) have X or Ys that differ from the geometry by more than 0.1 m']
We also need to update the length of a few elements in the network to be consistent with the new projection This is not strictly necessary, but minor differences may arise from how GeoPandas computes lengths
with commit_and_close(new_net_file, spatial=True) as conn:
for table in ("Link", "Road_Connectors", "Transit_Links", "Transit_Bike", "Transit_Walk"):
conn.execute(f"update {table} set length=round(ST_Length(geo), 8)")
Compute the overlay between the zone and the block group geometries
new_net = Network.from_file(new_net_file)
2026-09-01 07:25:22 UTC+0000 - Working with file on /tmp/Grid-Supply_reprojected.sqlite
Let’s compare the distances now
new_lengths = new_net.tables.get("Link")[["link", "length"]].set_index("link")
new_lengths.rename(columns={"length": "new_length"}, inplace=True)
old_lengths = old_net.tables.get("Link")[["link", "length"]].set_index("link")
old_lengths.rename(columns={"length": "old_length"}, inplace=True)
old_lengths.join(new_lengths).plot.scatter("old_length", "new_length")
<Axes: xlabel='old_length', ylabel='new_length'>
new_net.close()
old_net.close()
Total running time of the script: (0 minutes 5.088 seconds)
