Creating external locations#
In this example, we show how to use Polaris-Studio and GeoPandas to create external locations along roads that traverse the boundary of the modelling area.
Imports#
from pathlib import Path
import geopandas as gpd
from polaris.network.consistency.network_objects.location import Location
from polaris.network.consistency.network_objects.location_links import link_types_for_ext
from polaris.network.network import Network
from polaris.utils.database.db_utils import commit_and_close
⚠️ Friendly exception handler is disabled via FRIENDLY_ERRORS_DISABLED
project_file = Path("/tmp/Bloomington_external_locations/Bloomington-Supply.sqlite")
net = Network.from_file(project_file, False)
net.upgrade()
2026-09-01 07:24:55 UTC+0000 - Working with file on /tmp/Bloomington_external_locations/Bloomington-Supply.sqlite
2026-09-01 07:24:55 UTC+0000 - Upgrading Supply database at location /tmp/Bloomington_external_locations/Bloomington-Supply.sqlite
2026-09-01 07:24:55 UTC+0000 -   No migrations to apply
2026-09-01 07:24:55 UTC+0000 - Upgrading Supply database at location /tmp/Bloomington_external_locations/Bloomington-Supply.sqlite: Done in 0:00:00.010083 seconds
<polaris.network.network.Network object at 0x7fa82f2728d0>
Create the new model supply and open it We would normally use the national network as the source of roads entering and exiting the model area For the sake of an example, let’s use the Bloomington network itself
national_file = Path("/tmp/Bloomington_external_locations/Bloomington-Supply.sqlite")
national_net = Network.from_file(national_file, False)
Grabbing the necessary layers#
We also make sure that the layers are in the same projection
zone_layer = net.tables.get("zone")
national_links = national_net.tables.get("link").to_crs(zone_layer.crs)
We can be a little fancier and put a little buffer around all zones before we dissolve them This avoids problems with all sorts of imprecisions in the zone boundaries All Polaris models have projections in meters, so we can just go ahead and add a 10m buffer This would be a disaster if we were working in lat/lon
zone_polygon = zone_layer.buffer(10).union_all()
model_boundary = zone_polygon.boundary
Closes project#
net.close()
Total running time of the script: (0 minutes 14.148 seconds)
Gallery generated by Sphinx-Gallery
