Analysing Population Synthesis
Analysing Population Synthesis#
In this example we show how to examine the performance of the Population Synthesizer.
sphinx_gallery_thumbnail_path = ‘../../examples/result_analysis/pop_synth.png’
from pathlib import Path
from polaris.analyze.popsyn_analysis import PopsynComparator
from polaris.prepare.popsyn.linker_file import LinkerFile
from polaris.utils.logging_utils import polaris_logging  # noqa: E402
from polaris.utils.testing.temp_model import TempModel
polaris_logging()
project_dir = TempModel("Bloomington")
iteration_folder = project_dir / "Bloomington_iteration_2"
sample_factor = 0.25
comp = PopsynComparator(iteration_folder, sample_factor, LinkerFile(project_dir / "linker_file.txt"))
comp.summarise()
Comparison against controls#
When examining the below plots, the column title refers to the kind of control variable - household (HH) or person (PERSON) level. Note that columns starting with TEST are not directly controlled to.
PUMA level#
Note that linear regression stats will be meaningless for a model with one PUMA only, as is the case here.
comp.generate_comparison_plots(geo_level=1)
Tract level#
comp.generate_comparison_plots(geo_level=0)
Gallery generated by Sphinx-Gallery
