Migrate (update) databases
Migrate (update) databases#
In this example we show how to upgrade a model database to the latest version of Polaris.
icon credits: https://c2.staticflickr.com/2/1049/5142119589_1aaf74ded4_b.jpg
import shutil
from pathlib import Path
from polaris import Polaris
from polaris.utils.testing.temp_model import TempModel
# Let's open the model
project = Polaris.from_dir(TempModel("Grid"))
# 1. Migration Manager
# The easiest way is to just point the migration manager at each of your supply and demand databases and let it do
# what it can to bring them up to speed with the latest requirements from the polaris executable.
# If the database is older, you will get a warning and it may fail. If so try method #2 below
project.upgrade()
2. Dump and Reload#
Finally, if your database is too old to work with migrations (<2022), you can always try to dump and reload the database to csv to re-populate it with all the columns, tables and default values that are coded into polaris.
from polaris.utils.database.db_utils import read_and_close
from polaris.utils.database.database_dumper import dump_database_to_csv
from polaris.project.project_restorer import create_db_from_csv
from polaris.utils.database.standard_database import DatabaseType
from tempfile import mkdtemp
# We export the supply database to text
export_dir = Path(mkdtemp(prefix="my_new_db"))
with read_and_close(project.supply_file, spatial=True) as conn:
    dump_database_to_csv(conn, export_dir / "supply", None)
# We export the demand database to text
with read_and_close(project.demand_file, spatial=True) as conn:
    dump_database_to_csv(conn, export_dir / "demand", None)
# Rebuild the files
# Supply
create_db_from_csv(
    export_dir / "Grid-Supply_new.sqlite",
    DatabaseType.Supply,
    signal=None,
    overwrite=False,
    jumpstart=True,
# Demand
create_db_from_csv(
    export_dir / "Grid-demand_new.sqlite", export_dir / "demand", DatabaseType.Demand, signal=None, overwrite=False
# replace files into the model folder
shutil.copy(export_dir / "Grid-Supply_new.sqlite", project.supply_file)
shutil.copy(export_dir / "Grid-demand_new.sqlite", project.demand_file)
Gallery generated by Sphinx-Gallery
