Note
Go to the end to download the full example code.
Disaggregate zone-level demand to locations with time-of-day periods (including wrap-around)#
This example shows how to: - Load zones and locations from the Grid model - Create a small synthetic zone-to-zone demand table - Disaggregate those trips to origin/destination locations - Assign random start times using four time periods, one of which wraps around midnight (20:00–06:00)
Imports
from pathlib import Path
import numpy as np
import pandas as pd
from polaris import Polaris
from polaris.prepare.demand.demand_disaggregation import (
disaggregate_column,
assign_random_start_time,
from polaris.utils.database.data_table_access import DataTableAccess
model_dir = Path("/tmp/Grid")
supply_file = Polaris.from_dir(model_dir).supply_file
Read Zones and Locations tables from the Supply database
dta = DataTableAccess(supply_file)
zones = dta.get("Zone")[["zone"]] # GeoDataFrame with at least columns: zone, geo
locations = dta.get("Location")[["location", "zone"]] # GeoDataFrame with at least: location, zone, land_use, link, geo
Build a small synthetic zone-to-zone demand table We’ll pick a handful of zones that actually have locations and create random flows between them.
rng = np.random.default_rng(123)
origs = zones.sample(10, random_state=42).zone.to_numpy() # For display purposes only
dests = zones.sample(10, random_state=24).zone.to_numpy() # For display purposes only
flows = np.random.rand(10) * 5 # random number of trips between 0 and 5
zone_demand = pd.DataFrame({"zone_origin": origs, "zone_dest": dests, "trips": flows})
zone_demand.head()
This is what the locations dataframe need to look like
locations.head()
Disaggregate to locations using the helper in polaris.prepare.demand.demand_disaggregation This expands each OD row into individual trips and assigns origin/destination locations in the matching zones.
# Robust rounding ensures a better match to the original totals by making multiple attempts of
# stochastic rounding. It is not needed in the vast majority of cases
trips_df = disaggregate_column(zone_demand, "trips", locations, seed=42, robust_rounding=False)
print("\nTrip-level disaggregated data (columns):", trips_df.columns.tolist())
# This is what the trips dataframe with your aggregate trips need to look like (the name of the trips column can be
# different, as that is parameter in the disaggregation procedure
trips_df.head()
Trip-level disaggregated data (columns): ['zone_origin', 'zone_dest', 'trips', 'trip_id', 'origin_location', 'dest_location']
Define four time periods and assign random start times One period wraps around midnight (20:00 → 06:00 next day).
temporal_dist = pd.DataFrame(
"start_hour": [6.0, 10.0, 16.0, 20.0],
# end_hour <= 24; wrap-around handled internally for start > end by adding 24 to end
"end_hour": [10, 16, 20, 6.0],
# proportions must sum to 1.0
"proportion": [0.20, 0.40, 0.20, 0.20],
This is what the temporal_dist dataframe looks like
temporal_dist
trips_with_time = assign_random_start_time(trips_df, temporal_dist)
trips_with_time.head()
Let’s verify the assigned start times roughly match the desired proportions
starts_h = trips_with_time["start"].to_numpy() / 3600.0
period_masks = [
(starts_h >= 6) & (starts_h < 10),
(starts_h >= 10) & (starts_h < 16),
(starts_h >= 16) & (starts_h < 20),
(starts_h >= 20) | (starts_h < 6), # wrap-around
counts = np.array([m.sum() for m in period_masks], dtype=float)
print("\nAssigned starts by period (counts):", counts.astype(int).tolist())
print("Proportions:", np.round(counts / counts.sum(), 3).tolist())
Assigned starts by period (counts): [1, 13, 2, 5]
Proportions: [0.048, 0.619, 0.095, 0.238]
Show a compact preview: origin/destination locations and departure time in HH:MM
preview = trips_with_time[["zone_origin", "zone_dest", "origin_location", "dest_location", "start"]].copy()
preview["start_hm"] = (preview["start"] // 60).astype(int).map(lambda m: f"{m // 60:02d}:{m % 60:02d}")
print("\nPreview (first 10 trips):")
preview.head(10)
Total running time of the script: (0 minutes 0.154 seconds)
